EAPS PDU being dropped because the SNAP value is invalid.
Possible programming error. May have to capture packet using sniffer, and comparing with packet data at sending stations egress port. If sending station's packet itself has an incorrect SNAP Id, then most likely programming error while packet being created. If the sending station's packet data differs from this packet, it would need further troubleshooting to isolate where in the network the SNAP field is getting modified.
Warning
%slotPort%, %vlan% - SNAP (%snap%) is invalid. Correct value is (%defaultSnap%)
| Name | Type |
| slotPort | SlotPort |
| vlan | VLAN |
| snap | xInt32 |
| defaultSnap | xInt32 |
